Design and Optimization of a Digital Baseband Receiver ASIC for GSM/EDGE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper addresses complexity issues at algorithmic and architectural level of digital baseband receiver ASIC design for the standards GSM/GPRS/EDGE, in order to reduce power consumption and die area as desired for cellular applications. To this end, the hardware implementation of a channel shortening pre-filter combined with a delayed decision-feedback sequence estimator (DFSE) for channel equalization is described. The digital receiver back-end including a flexible Viterbi decoder implementation is presented and hardware savings that can be achieved by using hard-decisions are discussed. Design trade-offs are highlighted to prove the efficiency of the implemented 2.5G multi-mode architecture. The ASIC in 0.13 μm CMOS technology occupies 1.0 mm2 and dissipates only 1.3 mW in fastest EDGE data transmission mode.
978-3-642-28566-0_5_Chapter.pdf (1.99 Mo) Télécharger le fichier
hal-01515990 , version 1 (28-04-2017)
Paternité
Christian Benkeser, Qiuting Huang. Design and Optimization of a Digital Baseband Receiver ASIC for GSM/EDGE. 18th International Conference on Very Large Scale Integration (VLSISOC), Sep 2010, Madrid, Spain. pp.100-127, ⟨10.1007/978-3-642-28566-0_5⟩. ⟨hal-01515990⟩
235 Consultations
264 Téléchargements
