Abstract : A simple method to tune the output pole of a passive mixer is proposed which leads to up to 33 dB improvement in an IEEE 802.15.4 standard compatible receiver’s IF section IIP3. This method is used in the design of an ultra-low power receiver front-end which consumes just 2.2 mW from a 1-V supply while achieving a SSB NF of approximately 9 dB. The energy-aware architecture allows for a 70 % reduction in the nominal power consumption (down to 0.7 mW) under strong signal conditions while improving the receiver’s IIP3 and not affecting the receiver’s input matching. The receiver is designed in a 0.18-μm RFCMOS technology.
https://hal.inria.fr/hal-01515991 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, April 28, 2017 - 2:29:44 PM Last modification on : Thursday, March 5, 2020 - 5:40:12 PM
Aaron Do, Chirn Chye Boon, Manthena Vamshi Krishna, Anh Manh Do, Kiat Seng Yeo. A 1-V CMOS Ultralow-Power Receiver Front End for the IEEE 802.15.4 Standard Using Tuned Passive Mixer Output Pole. 18th International Conference on Very Large Scale Integration (VLSISOC), Sep 2010, Madrid, Spain. pp.1-21, ⟨10.1007/978-3-642-28566-0_1⟩. ⟨hal-01515991⟩
