Anh Manh Do, and Kiat Seng Yeo Self-Timed Rings: A Promising Solution for Generating High-Speed High-Resolution Low-Phase Noise Clocks, p.22 ,
and Fabio Cenni A 1.8-V 3.6-mW 2.4-GHz Fully Integrated CMOS Frequency Synthesizer for the IEEE 802.15, p.69 ,
100 Christian Benkeser and Qiuting Huang VLSI Implementation of Hard-and Soft-Output Sphere Decoding for Wide-Band MIMO Systems, 128 Christoph Studer, Markus Wenk, and Andreas Burg Joint Optimization of Low-Power DCT Architecture and Efficient Quantization Technique for Embedded Image Compression, p.155 ,
Alfalou Fast Fixed-Point Optimization of DSP Algorithms, p.182 ,
López, and Carlos Carreras Design and Verification of Lazy and Hybrid Implementations of the SELF, p.206 ,
Stevens Adaptation Strategies in Multiprocessors System on, p.233 ,
Diéguez Smart Camera System-on-Chip Architecture for Real-Time Brush Based Interactive Painting Systems, p.339 ,
