A comparison of neighbor search algorithms for large rigid molecules, Journal of Computational Chemistry, vol.250, issue.13, pp.2865-2877, 2011. ,
DOI : 10.1016/0009-2614(95)01434-9
URL : https://hal.archives-ouvertes.fr/hal-00748053
Acta Cryst, pp.357-360, 1961. ,
The Protein Data Bank, Nucleic Acids Research, vol.28, issue.1, pp.235-242, 2000. ,
DOI : 10.1093/nar/28.1.235
URL : https://academic.oup.com/nar/article-pdf/28/1/235/9895144/280235.pdf
How Water Meets a Very Hydrophobic Surface, Physical Review Letters, vol.105, issue.3, p.37803, 2010. ,
DOI : 10.1103/PhysRevLett.54.114
URL : http://arxiv.org/abs/1006.4620
Structure Analysis by Small-angle X-ray and Neutron Scattering, 1987. ,
DOI : 10.1007/978-1-4757-6624-0
An improved method for calculating the contribution of solvent to the X-ray diffraction pattern of biological molecules, Journal of Applied Crystallography, vol.11, issue.6, pp.693-694, 1978. ,
DOI : 10.1107/S0021889878014296
Impact and progress in small and wide angle X-ray scattering (SAXS and WAXS), Current Opinion in Structural Biology, vol.23, issue.5, pp.748-754, 2013. ,
DOI : 10.1016/j.sbi.2013.06.007
Improved Fitting of Solution X-ray Scattering Data to Macromolecular Structures and Structural Ensembles by Explicit Water Modeling, Journal of the American Chemical Society, vol.132, issue.44, pp.15484-15486, 2010. ,
DOI : 10.1021/ja106173n
A hierarchical algorithm for fast debye summation with applications to small angle scattering, Journal of Computational Chemistry, vol.132, issue.25, pp.1981-1996, 2012. ,
DOI : 10.1021/ja100447p
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3425727
The meaning of the average of |F|2 for large values of the interplanar spacing, Acta Crystallographica, vol.6, issue.8, pp.731-736, 1953. ,
DOI : 10.1107/S0365110X53002040
Robust, high-throughput solution structural analyses by small angle X-ray scattering (SAXS), Nature Methods, vol.334, issue.8, pp.606-612, 2009. ,
DOI : 10.3109/00365515309094189
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3094553
An Ordered Water Molecular Assembly Structure in a Slit-Shaped Carbon Nanospace, The Journal of Physical Chemistry, vol.99, issue.25, pp.10075-10076, 1995. ,
DOI : 10.1021/j100025a004
): an open-source software for biomolecular small-angle scattering, Journal of Applied Crystallography, vol.45, issue.3, pp.587-593, 2012. ,
DOI : 10.1107/S0021889812015786
Acta Cryst, pp.561-567, 2012. ,
Handbook of Fourier Analysis and its Applications, 2008. ,
Small-angle scattering. Information content and error analysis, Journal of Applied Crystallography, vol.13, issue.2, pp.168-175, 1980. ,
DOI : 10.1107/S002188988001179X
Simulated x-ray scattering of protein solutions using explicit-solvent models, The Journal of Chemical Physics, vol.130, issue.13, p.134114, 2009. ,
DOI : 10.1063/1.1517040
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2852435
program package for small-angle scattering data analysis, Journal of Applied Crystallography, vol.36, issue.2, pp.342-350, 2012. ,
DOI : 10.1107/S0021889812007662/fs5015sup1.pdf
AquaSAXS: a web server for computation and fitting of SAXS profiles with non-uniformally hydrated atomic models, Nucleic Acids Research, vol.39, issue.suppl_2, pp.184-189, 2011. ,
DOI : 10.1093/nar/gkr430
URL : https://hal.archives-ouvertes.fr/cea-00666216
Numerical Recipes: The Art of Scientific Computing, 2007. ,
Accurate assessment of mass, models and resolution by small-angle scattering, Nature, vol.94, issue.7446, pp.477-481, 2013. ,
DOI : 10.1529/biophysj.107.113415
Super-Resolution in Solution X-Ray Scattering and Its Applications to Structural Systems Biology, Annual Review of Biophysics, vol.42, issue.1, pp.415-441, 2013. ,
DOI : 10.1146/annurev-biophys-083012-130301
FoXS: a web server for rapid computation and fitting of SAXS profiles, Nucleic Acids Research, vol.38, issue.Web Server, pp.540-544, 2010. ,
DOI : 10.1093/nar/gkq461
Accurate SAXS Profile Computation and its Assessment by Contrast Variation Experiments, Biophysical Journal, vol.105, issue.4, pp.962-974, 2013. ,
DOI : 10.1016/j.bpj.2013.07.020
URL : http://doi.org/10.1016/j.bpj.2013.07.020
Encyclopedia of Analalytical Chemistry, pp.1-34, 2014. ,
Ein neues Verfahren zur Bestimmung der Oberfl??chenform und der inneren Struktur von gel??sten globul??ren Proteinen aus R??ntgenkleinwinkelmessungen, Zeitschrift f??r Physikalische Chemie, vol.72, issue.4_6, pp.177-184, 1970. ,
DOI : 10.1524/zpch.1970.72.4_6.177
Acta Cryst, pp.297-306, 1970. ,
Mathematical methods in small-angle scattering data analysis, Journal of Applied Crystallography, vol.24, issue.5, pp.485-492, 1991. ,
DOI : 10.1107/S0021889891001280
??? a Program to Evaluate X-ray Solution Scattering of Biological Macromolecules from Atomic Coordinates, Journal of Applied Crystallography, vol.28, issue.6, pp.768-773, 1995. ,
DOI : 10.1107/S0021889895007047
Information content and retrieval in solution scattering studies. I. Degrees of freedom and data reduction, Journal of Applied Crystallography, vol.15, issue.3, pp.289-300, 1982. ,
DOI : 10.1107/S0021889882012011
Advanced ensemble modelling of flexible macromolecules using X-ray solution scattering, IUCrJ, vol.107, issue.2, pp.207-217, 2015. ,
DOI : 10.1107/S205225251500202X/fc5007sup1.pdf
URL : http://doi.org/10.1107/s205225251500202x
What x rays can tell us about the interfacial profile of water near hydrophobic surfaces, Physical Review B, vol.19, issue.3, p.35431, 2013. ,
DOI : 10.1103/PhysRevB.85.035406
SASBDB, a repository for biological small-angle scattering data, Nucleic Acids Research, vol.43, issue.D1, pp.357-363, 2015. ,
DOI : 10.1093/nar/gku1047
URL : http://doi.org/10.1093/nar/gku1047
shape determination in small-angle scattering, Journal of Applied Crystallography, vol.36, issue.3, pp.860-864, 2003. ,
DOI : 10.1107/S0021889803000268
Acta Cryst, pp.416-431, 1995. ,
Rapid and accurate calculation of small-angle scattering profiles using the golden ratio, Journal of Applied Crystallography, vol.96, issue.4, pp.1171-1177, 2013. ,
DOI : 10.1016/j.bpj.2009.03.036
A Rapid Coarse Residue-Based Computational Method for X-Ray Solution Scattering Characterization of Protein Folds and Multiple Conformational States of Large Protein Complexes, Biophysical Journal, vol.96, issue.11, pp.4449-4463, 2009. ,
Accurate Flexible Fitting of High-Resolution Protein Structures to Small-Angle X-Ray Scattering Data Using a Coarse-Grained Model with??Implicit Hydration Shell, Biophysical Journal, vol.101, issue.12, pp.2981-2991, 2011. ,
DOI : 10.1016/j.bpj.2011.11.003
