New interface
Journal articles
Scheduling Independent Moldable Tasks on Multi-Cores with GPUs
Abstract : We present a new approach for scheduling independent tasks on multiple CPUs and multiple GPUs. The tasks are assumed to be parallelizable on CPUs using the moldable model: the final number of cores allotted to a task can be decided and set by the scheduler. More precisely, we design an algorithm aiming at minimizing the makespan—the maximum completion time of all tasks—for this scheduling problem. The proposed algorithm combines a dual approximation scheme with a fast integer linear program (ILP). It determines both the partitioning of the tasks, i.e., whether a task should be mapped to CPUs or a GPU, and the number of CPUs allotted to a moldable task if mapped to the CPUs. A worst-case analysis shows that the algorithm has an approximation ratio of 3 2 +. Since the time complexity of the ILP-based algorithm could be non-polynomial, we also present a polynomial-time algorithm with an approximation ratio of 2 +. We complement the theoretical analysis of our two novel algorithms with a simulation study. In these simulations, we compare our algorithms to a modified version of the classical HEFT algorithm, which we adapted to handle moldable tasks. The simulation results show that our algorithm with the 3 2 +-approximation ratio produces significantly shorter schedules than the modified HEFT for most of the instances. In addition, our results provide evidence that our ILP-based algorithm can solve larger problem instances in a reasonable amount of time.
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-01516752
Contributor : Grégory Mounié Connect in order to contact the contributor
Submitted on : Tuesday, May 2, 2017 - 10:59:42 AM
Last modification on : Friday, July 8, 2022 - 10:09:09 AM
Long-term archiving on: : Thursday, August 3, 2017 - 12:30:54 PM
File
halmoldableLP.pdf
Identifiers
Citation
Raphaël Bleuse, Sascha Hunold, Safia Kedad-Sidhoum, Florence Monna, Grégory Mounié, et al.. Scheduling Independent Moldable Tasks on Multi-Cores with GPUs. IEEE Transactions on Parallel and Distributed Systems, 2017, pp.14. ⟨10.1109/TPDS.2017.2675891⟩. ⟨hal-01516752⟩
Share
Metrics
Record views
282
Files downloads
310
