Abstract : This paper presents a privacy-friendly mobile authentication solution. It addresses several shortcomings of conventional methods, such as passwords and smartcard solutions. It also meets the needs of an increasingly mobile user. Trust in the client computer is minimal and the authentication is entirely delegated to the smartphone, which makes it portable across different workstations. Our approach involves authentication using securely stored credentials on the smartphone. The client workstation does not need to be modified, whereas only minor changes to the Web server are required.
https://hal.inria.fr/hal-01517605 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, May 3, 2017 - 2:28:09 PM Last modification on : Thursday, February 21, 2019 - 10:31:47 AM Long-term archiving on: : Friday, August 4, 2017 - 1:30:26 PM
Faysal Boukayoua, Jan Vossaert, Bart De Decker, Vincent Naessens. Using a Smartphone to Access Personalized Web Services on a Workstation. 7th PrimeLife International Summer School (PRIMELIFE), Sep 2011, Trento, Italy. pp.144-156, ⟨10.1007/978-3-642-31668-5_11⟩. ⟨hal-01517605⟩
