An Efficient Approach for Privacy Preserving Distributed K-Means Clustering Based on Shamir’s Secret Sharing Scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Privacy preserving data mining has gained considerable attention because of the increased concerns to ensure privacy of sensitive information. Amongst the two basic approaches for privacy preserving data mining, viz. Randomization based and Cryptography based, the later provides high level of privacy but incurs higher computational as well as communication overhead. Hence, it is necessary to explore alternative techniques that improve the overheads. In this work, we propose an efficient, collusion-resistant cryptography based approach for distributed K-Means clustering using Shamir’s secret sharing scheme. As we show from theoretical and practical analysis, our approach is provably secure and does not require a trusted third party. In addition, it has negligible computational overhead as compared to the existing approaches.
978-3-642-29852-3_9_Chapter.pdf (317.2 Ko) Télécharger le fichier
hal-01517655 , version 1 (03-05-2017)
Paternité
Sankita Patel, Sweta Garasia, Devesh Jinwala. An Efficient Approach for Privacy Preserving Distributed K-Means Clustering Based on Shamir’s Secret Sharing Scheme. 6th International Conference on Trust Management (TM), May 2012, Surat, India. pp.129-141, ⟨10.1007/978-3-642-29852-3_9⟩. ⟨hal-01517655⟩
187 Consultations
147 Téléchargements
