A Multi-Armed Bandit Model Selection for Cold-Start User Recommendation - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
How can we effectively recommend items to a user about whom we have no information? This is the problem we focus on, known as the cold-start problem. In this paper, we focus on the cold user problem. In most existing works, the cold-start problem is handled through the use of many kinds of information available about the user. However, what happens if we do not have any information? Recommender systems usually keep a substantial amount of prediction models that are available for analysis. Moreover, recommendations to new users yield uncertain returns. Assuming a number of alternative prediction models is available to select items to recommend to a cold user, this paper introduces a multi-armed bandit based model selection, named PdMS. In comparison with two baselines, PdMS improves the performance as measured by the nDCG. These improvements are demonstrated on real, public datasets.
umap2017.4hal.pdf (936.69 Ko) Télécharger le fichier
Origin : Explicit agreement for this submission
Dates and versions
hal-01517967 , version 1 (12-05-2017)
Identifiers
  • HAL Id : hal-01517967 , version 1
Cite
Crícia Z Felício, Klérisson V R Paixão, Celia a Z Barcelos, Philippe Preux. A Multi-Armed Bandit Model Selection for Cold-Start User Recommendation. 25th ACM Conference on User Modelling, Adaptation and Personalization (UMAP), Jul 2017, Bratislava, Slovakia. ⟨hal-01517967⟩
279 View
2127 Download
Share
