Conference papers
Parametric and Uncertainty Computations with Tensor Product Representations
Abstract : Computational uncertainty quantification in a probabilistic setting is a special case of a parametric problem. Parameter dependent state vectors lead via association to a linear operator to analogues of covariance, its spectral decomposition, and the associated Karhunen-Loève expansion. From this one obtains a generalised tensor representation The parameter in question may be a tuple of numbers, a function, a stochastic process, or a random tensor field. The tensor factorisation may be cascaded, leading to tensors of higher degree. When carried on a discretised level, such factorisations in the form of low-rank approximations lead to very sparse representations of the high dimensional quantities involved. Updating of uncertainty for new information is an important part of uncertainty quantification. Formulated in terms or random variables instead of measures, the Bayesian update is a projection and allows the use of the tensor factorisations also in this case.
Document type :
Conference papers
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/hal-01518676
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, May 5, 2017 - 10:55:58 AM
Last modification on : Friday, November 19, 2021 - 12:42:03 PM
Long-term archiving on: : Sunday, August 6, 2017 - 12:39:28 PM
File
978-3-642-32677-6_9_Chapter.pd...
Identifiers
Citation
Hermann G. Matthies, Alexander Litvinenko, Oliver Pajonk, Bojana V. Rosić, Elmar Zander. Parametric and Uncertainty Computations with Tensor Product Representations. 10th Working Conference on Uncertainty Quantification in Scientific Computing (WoCoUQ), Aug 2011, Boulder, CO, United States. pp.139-150, ⟨10.1007/978-3-642-32677-6_9⟩. ⟨hal-01518676⟩
Share
Metrics
Record views
129
Files downloads
172
