Peter Harris, and Clare Matthews Model-Based Interpolation, Prediction, and Approximation ,
Sharp From Quantification to Visualization: A Taxonomy of Uncertainty Visualization Approaches, 226 Kristin Potter, Paul Rosen, and Chris R. Johnson Efficient Computation of Observation Impact in 4D-Var Data ,
Eric De Sturler, and Emil Constantinescu Interval Based Finite Elements for Uncertainty Quantification in Engineering Mechanics, p.265 ,
Reducing the Uncertainty when Approximating the Solution of ODEs, p.280 ,
Hot Topics Uncertainties in Predictions of Material Performance Using Experimental Data That Is Only Distantly Related to the System of Interest, p.294 ,
Oberkampf A Note on Uncertainty in Real-Time, p.312 ,
