Making Movies from Make-Believe Games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pretend play is a storytelling technique, naturally used from very young ages, which relies on object substitution to represent the characters of the imagined story. We propose "Make-believe", a system for making movies from pretend play by using 3D printed figurines as props. We capture the rigid motions of the figurines and the gestures and facial expressions of the storyteller using Kinect cameras and IMU sensors and transfer them to the virtual story-world. As a proof-of-concept, we demonstrate our system with an improvised story involving a prince and a witch, which was successfully recorded and transferred into 3D animation.
paper1014_CRC.pdf (583.72 Ko) Télécharger le fichier
wicedcrc.mp4 (8.75 Mo) Télécharger le fichier
Format : Figure, Image
hal-01518981 , version 1 (05-05-2017)
hal-01518981 , version 2 (11-07-2017)
  • HAL Id : hal-01518981 , version 1
Adela Barbulescu, Maxime Garcia, Dominique Vaufreydaz, Marie-Paule Cani, Rémi Ronfard, et al.. Making Movies from Make-Believe Games. 6th Workshop on Intelligent Cinematography and Editing (WICED 2017), Apr 2017, Lyon, France. ⟨hal-01518981v1⟩
1093 Consultations
441 Téléchargements
