Theoretical performance of voltage multiplier circuits, IEEE Journal of Solid-State Circuits, vol.6, issue.3, pp.132-135, 1971. ,
DOI : 10.1109/JSSC.1971.1049670
On-chip high-voltage generation in MNOS integrated circuits using an improved voltage multiplier technique, IEEE Journal of Solid-State Circuits, vol.11, issue.3, pp.374-378, 1976. ,
DOI : 10.1109/JSSC.1976.1050739
Analysis and modeling of on-chip high-voltage generator circuits for use in EEPROM circuits, IEEE Journal of Solid-State Circuits, vol.24, issue.5, pp.1372-1380, 1989. ,
DOI : 10.1109/JSSC.1989.572617
Optimization of word-line booster circuits for low-voltage flash memories, IEEE Journal of Solid-State Circuits, vol.34, issue.8, pp.1091-1098, 1999. ,
DOI : 10.1109/4.777107
Charge-pump circuits: power-consumption optimization, IEEE Transactions on Circuits and Systems I: Fundamental Theory and Applications, vol.49, issue.11, pp.1535-1542, 2002. ,
DOI : 10.1109/TCSI.2002.804544
A technique to increase the efficiency of high-voltage charge pumps, IEEE Transactions on Circuits and Systems II: Express Briefs, vol.53, issue.5, pp.364-368, 2006. ,
DOI : 10.1109/TCSII.2006.869922
Charge Pump Circuits: An Overview on Design Strategies and Topologies, IEEE Circuits and Systems Magazine, vol.10, issue.1, pp.31-45, 2010. ,
DOI : 10.1109/MCAS.2009.935695
A Switch-Resistance-Aware Dickson Charge Pump Model for Optimizing Clock Frequency, IEEE Transactions on Circuits and Systems II: Express Briefs, vol.58, issue.6, pp.336-340, 2011. ,
DOI : 10.1109/TCSII.2011.2158166
Emergency power supply for small computer systems, 1991., IEEE International Sympoisum on Circuits and Systems, pp.1065-1068, 1991. ,
DOI : 10.1109/ISCAS.1991.176549
Charge pump circuit with exponetral (exponential) multiplication. US Patent 5, 1995. ,
N-stage exponential charge pumps, charging stages therefor and methods of operation therefore, US Patent, vol.7397, p.299, 2008. ,
Gain-and Offset-Compensated Switched-Capacitor Circuits, 1995. ,
Charge redistribution loss consideration in optimal charge pump design, IEEE Int'l Symp. Circ. Syst, pp.1895-1898, 2005. ,
Design and analysis of on-chip charge pumps for micro-power energy harvesting applications, 2011 IEEE/IFIP 19th International Conference on VLSI and System-on-Chip, pp.374-379, 2011. ,
DOI : 10.1109/VLSISoC.2011.6081612
URL : https://hal.archives-ouvertes.fr/hal-01519762
Analysis of charge pumps using charge balance, IEEE Power Elec. Specialists Conf, pp.1491-1496, 2000. ,
A New Approach to Reducing Output Ripple in Switched-Capacitor-Based Step-Down DC–DC Converters, IEEE Transactions on Power Electronics, vol.21, issue.6, pp.1548-1555, 2006. ,
DOI : 10.1109/TPEL.2006.882973
A DC-DC charge pump design based on voltage doublers, IEEE Transactions on Circuits and Systems I: Fundamental Theory and Applications, vol.48, issue.3, pp.350-359, 2001. ,
DOI : 10.1109/81.915390
Component-efficient multi-phase switched capacitor DC-DC converter with configurable conversion ratios for LCD driver applications, IEEE Trans. Circ. Syst. II, vol.55, issue.8, pp.753-757, 2008. ,
