Low-complexity reconfigurable complex constant multiplication for FFTs, 2009 IEEE International Symposium on Circuits and Systems, pp.24-27, 2009. ,
DOI : 10.1109/ISCAS.2009.5117961
A novel optimal single constant multiplication algorithm, Proceedings of the 47th Design Automation Conference on, DAC '10, pp.613-616, 2010. ,
DOI : 10.1145/1837274.1837424
FIR Filter Synthesis Algorithms for Minimizing the Delay and the Number of Adders, IEEE Trans. on Circuits and Systems II: Analog and Digital Signal Processing, vol.48, issue.8, pp.770-777, 2001. ,
Subexpression sharing in filters using canonic signed digit multipliers, IEEE Transactions on Circuits and Systems II: Analog and Digital Signal Processing, vol.43, issue.10, pp.677-688, 1996. ,
DOI : 10.1109/82.539000
Some Optimizations of Hardware Multiplication by Constant Matrices, IEEE Transactions on Computers, vol.54, issue.10, pp.1271-1282, 2005. ,
DOI : 10.1109/TC.2005.168
URL : https://hal.archives-ouvertes.fr/lirmm-00113092
A Suggestion for a Fast Multiplier, IEEE Transactions on Electronic Computers, vol.13, issue.1, pp.14-17, 1964. ,
DOI : 10.1109/PGEC.1964.263830
High radix booth multipliers using reduced area adder trees, Proceedings of 1994 28th Asilomar Conference on Signals, Systems and Computers, pp.545-549, 1994. ,
DOI : 10.1109/ACSSC.1994.471512
Number-splitting with shift-and-add decomposition for power and hardware optimization in linear DSP synthesis, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, vol.8, issue.4, pp.419-424, 2000. ,
DOI : 10.1109/92.863621
Multiple constant multiplications: efficient and versatile framework and algorithms for exploring common subexpression elimination, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.15, issue.2, pp.151-165, 1996. ,
DOI : 10.1109/43.486662
Exact and Approximate Algorithms for the Optimization of Area and Delay in Multiple Constant Multiplications, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.27, issue.6, pp.1013-1026, 2008. ,
DOI : 10.1109/TCAD.2008.923242
Multiplierless Realization of Linear DSP Transforms by Using Common Two-Term Expressions, The Journal of VLSI Signal Processing, vol.22, issue.3, pp.163-172, 1999. ,
DOI : 10.1023/A:1008125221674
Reducing Hardware Complexity of Linear DSP Systems by Iteratively Eliminating Two-Term Common Subexpressions, Proc. of Asia and South Pacific Design Automation Conference, pp.523-528, 2005. ,
Optimization Algorithms for the Multiplierless Realization of Linear Transforms, ACM Transactions on Design Automation of Electronic Systems, vol.17, issue.1, 2012. ,
DOI : 10.1145/2071356.2071359
Primitive operator digital filters, IEE Proc. G: Circuits, Devices and Systems, pp.401-412, 1991. ,
DOI : 10.1049/ip-g-2.1991.0066
Use of minimum-adder multiplier blocks in FIR digital filters, IEEE Transactions on Circuits and Systems II: Analog and Digital Signal Processing, vol.42, issue.9, pp.569-577, 1995. ,
DOI : 10.1109/82.466647
A novel approach to multiple constant multiplication using minimum spanning trees, The 2002 45th Midwest Symposium on Circuits and Systems, 2002. MWSCAS-2002., pp.652-655, 2002. ,
DOI : 10.1109/MWSCAS.2002.1187124
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.321.1568
Multiplierless multiple constant multiplication, ACM Transactions on Algorithms, vol.3, issue.2, 2007. ,
DOI : 10.1145/1240233.1240234
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.319.4035
Search algorithms for the multiple constant multiplications problem: Exact and approximate, Microprocessors and Microsystems, vol.34, issue.5, pp.151-162, 2010. ,
DOI : 10.1016/j.micpro.2009.10.001
Towards an Algorithm for Matrix Multiplier Blocks, Proc. of IEEE European Conference on Circuit Theory and Design, pp.1-4, 2003. ,
Low-Complexity Constant Coefficient Matrix Multiplication Using a Minimum Spanning Tree, Proc. of Nordic Signal Processing Symposium, pp.141-144, 2004. ,
Signed-digit Number Representation for Fast Parallel Arithmetic, IRE Trans. on Electronic Computers EC, pp.10-389, 1961. ,
DOI : 10.1109/tec.1961.5219227
Number Systems and Arithmetic, Advances in Computers, vol.6, pp.131-194, 1965. ,
DOI : 10.1016/S0065-2458(08)60420-9
Some complexity issues in digital signal processing, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.32, issue.5, pp.1037-1041, 1984. ,
DOI : 10.1109/TASSP.1984.1164433
Digital Arithmetic, 2003. ,
URL : https://hal.archives-ouvertes.fr/ensl-00542215
Lower Bounds for Constant Multiplication Problems, IEEE Transactions on Circuits and Systems II: Express Briefs, vol.54, issue.11, pp.974-978, 2007. ,
DOI : 10.1109/TCSII.2007.903212
Simultaneous Optimization of Delay and Number of Operations in Multiplierless Implementation of Linear Systems, Proc. of International Workshop on Logic Synthesis, 2005. ,
Xquasher, Proceedings of the 46th Annual Design Automation Conference on ZZZ, DAC '09, pp.254-257, 2009. ,
DOI : 10.1145/1629911.1629980
Multiplication by an Integer Constant, Institut National de Recherche en Informatique et en Automatique, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00072430
Finding the optimal tradeoff between area and delay in multiple constant multiplications, Microprocessors and Microsystems, vol.35, issue.8, pp.729-741, 2011. ,
DOI : 10.1016/j.micpro.2011.08.009
