Computing the Lambert W function in arbitrary-precision complex interval arithmetic
We describe an algorithm to evaluate all the complex branches of the Lambert W function with rigorous error bounds in interval arithmetic, which has been implemented in the Arb library. The classic 1996 paper on the Lambert W function by Corless et al. provides a thorough but partly heuristic numerical analysis which needs to be complemented with some explicit inequalities and practical observations about managing precision and branch cuts.
lambert.pdf (667.16 Ko)
Télécharger le fichier
plotb1y.pdf (136.88 Ko)
plotbb.pdf (172.84 Ko)
plottheta.pdf (133.48 Ko)
plotx.pdf (173.39 Ko)
wplot.pdf (229.86 Ko)
zplot.pdf (351.21 Ko)
zplot2.pdf (352.87 Ko)
