Modular polynomials on Hilbert surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We describe an evaluation/interpolation approach to compute modular polynomials on a Hilbert surface, which parametrizes abelian surfaces with maximal real multiplication. Under some heuristics we obtain a quasi-linear algorithm. The corresponding modular polynomials are much smaller than the ones on the Siegel threefold. We explain how to compute even smaller polynomials by using pullbacks of theta functions to the Hilbert surface, and give an application to the CRT method to construct class polynomials.
articleHilbert.pdf (663.19 Ko) Télécharger le fichier
hal-01520262 , version 1 (10-05-2017)
hal-01520262 , version 2 (09-09-2017)
hal-01520262 , version 3 (09-01-2020)
  • HAL Id : hal-01520262 , version 1
Enea Milio, Damien Robert. Modular polynomials on Hilbert surfaces. 2017. ⟨hal-01520262v1⟩
597 Consultations
593 Téléchargements
