Towards Collaborative Alignment of Engineering Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Kim Jansson
  • Fonction : Auteur
  • PersonId : 1000980
Iris Karvonen
  • Fonction : Auteur
  • PersonId : 1000979
Mikko Uoti
  • Fonction : Auteur
  • PersonId : 1000981
This paper reports further development of competence management in engineering networks through the consolidation of two different approaches for competence management; the Innovation and Engineering Maturity Model and the Project Alignment concept. To support the proactive competence management in collaborative networks the paper proposes first, further development of the IEMM into a more dynamic and networked structure and second, extension of the project alignment concept from the temporary project level to the more continuous organization, network level.
978-3-642-32775-9_47_Chapter.pdf (93.8 Ko) Télécharger le fichier
hal-01520464 , version 1 (10-05-2017)
Paternité
Kim Jansson, Iris Karvonen, Mikko Uoti. Towards Collaborative Alignment of Engineering Networks. 13th Working Confeence on Virtual Enterpries (PROVE), Oct 2012, Bournemouth, United Kingdom. pp.467-474, ⟨10.1007/978-3-642-32775-9_47⟩. ⟨hal-01520464⟩
46 Consultations
42 Téléchargements
