Detecting Glycosylations in Complex Samples - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
(1) , (1) , (1) , (1)
1
Glycoproteins are the highly diverse key element in the process of cell – cell recognition and host – pathogen interaction. It is this diversity that makes it a challenge to identify the glyco-peptides together with their modification from trypsin-digested complex samples in mass spectrometry studies. The biological approach is to isolate the peptides and separate them from their glycosylation to analyse both separately. Here we present an in-silico approach that analyses the combined spectra by using highly accurate data and turns previously established knowledge into algorithms to refine the identification process. It complements the established method, needs no separation, and works on the most readily available clinical sample of them all: Urine.
978-3-642-33409-2_25_Chapter.pdf (460.41 Ko) Télécharger le fichier
Dates and versions
hal-01521386 , version 1 (11-05-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Thorsten Johl, Manfred Nimtz, Lothar Jänsch, Frank Klawonn. Detecting Glycosylations in Complex Samples. 8th International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2012, Halkidiki, Greece. pp.234-243, ⟨10.1007/978-3-642-33409-2_25⟩. ⟨hal-01521386⟩
87 View
85 Download
Share
