Position and Velocity Predictions of the Piston in a Wet Clutch System during Engagement by Using a Neural Network Modeling - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
Yu Zhong
  • Function : Author
  • PersonId : 1007999
Gregory Pinte
  • Function : Author
  • PersonId : 1008003
Wim Symens
  • Function : Author
  • PersonId : 1008004
Julian Stoev
  • Function : Author
  • PersonId : 1008005
In a wet clutch system, a piston is used to compress the friction disks to close the clutch. The position and the velocity of the piston are the key effectors for achieving a good engagement performance. In a real setup, it is impossible to measure these variables. In this paper, we use transmission torque and slip to approximate the piston velocity and position information. By using this information, a process neural network is trained. This neural predictor shows good forecasting results on the piston position and velocity. It is helpful in designing a pressure profile which can result in a smooth and fast engagement in the future. This neural predictor can also be used in other model-based control techniques.
978-3-642-33409-2_49_Chapter.pdf (1.59 Mo) Télécharger le fichier
Dates and versions
hal-01521397 , version 1 (11-05-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Yu Zhong, Bart Wyns, Abhishek Dutta, Clara-Mihaela Ionescu, Gregory Pinte, et al.. Position and Velocity Predictions of the Piston in a Wet Clutch System during Engagement by Using a Neural Network Modeling. 8th International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2012, Halkidiki, Greece. pp.474-482, ⟨10.1007/978-3-642-33409-2_49⟩. ⟨hal-01521397⟩
35 View
246 Download
Share
