Engineering Design via Surrogate Modelling: A Practical Guide, 2008. ,
DOI : 10.1002/9780470770801
Combinatorial Development of Solid Catalytic Materials, 2009. ,
DOI : 10.1142/p620
Linear Integral Equations, 1950. ,
Sources and Applications of Integral Equations, SIAM Review, vol.19, issue.2, pp.241-278, 1977. ,
DOI : 10.1137/1019039
Integral equation models for image restoration: high accuracy methods and fast algorithms, Inverse Problems, vol.26, issue.4, 2010. ,
DOI : 10.1088/0266-5611/26/4/045006
Theoretical Numerical Analysis: A Functional Analysis Framework, 2005. ,
A neural network approach for solving Fredholm integral equations of the second kind, Neural Computing and Applications, pp.10-1007, 2010. ,
DOI : 10.1007/s00521-010-0489-y
Numerical solution of the second kind integral equations using radial basis function networks, Applied Mathematics and Computation, vol.174, issue.2, pp.877-883, 2006. ,
DOI : 10.1016/j.amc.2005.05.034
Some comparisons of complexity in dictionary-based and linear computational models, Neural Networks, vol.24, issue.2, pp.171-182, 2011. ,
DOI : 10.1016/j.neunet.2010.10.002
Can dictionary-based computational models outperform the best linear ones?, Neural Networks, vol.24, issue.8, pp.881-887, 2011. ,
DOI : 10.1016/j.neunet.2011.05.014
URL : http://www.sciencedirect.com/science?_ob=ShoppingCartURL&_method=add&_eid=1-s2.0-S0893608011001560&originContentFamily=serial&_origin=article&_ts=1480321175&md5=6f54ab4da7d4b962765404695ea94d29
Accuracy of approximations of solutions to Fredholm equations by kernel methods, Applied Mathematics and Computation, vol.218, issue.14, p.74817497, 2012. ,
DOI : 10.1016/j.amc.2012.01.015
Support Vector Machines, 2008. ,
Functional Analysis, 1991. ,
The Numerical Solution of Integral Equations of the Second Kind, 1997. ,
Methods of Mathematical Physic. Volume I, 1989. ,
On the exponential convergence of matching pursuits in quasi-incoherent dictionaries, IEEE Transactions on Information Theory, vol.52, issue.1, pp.255-261, 2006. ,
DOI : 10.1109/TIT.2005.860474
URL : https://hal.archives-ouvertes.fr/inria-00544945
Universal approximation bounds for superpositions of a sigmoidal function, IEEE Transactions on Information Theory, vol.39, issue.3, pp.930-945, 1993. ,
DOI : 10.1109/18.256500
Approximation error bounds that use VC-bounds, Proceedings of ICANN 1995, pp.295-302, 1995. ,
Neural net approximation, Proc. 7th Yale Workshop on Adaptive and Learning Systems, 1992. ,
Dimension-independent rates of approximation by neural networks Computer-Intensive Methods in Control and Signal Processing. The Curse of Dimensionality, pp.261-270, 1997. ,
High-dimensional approximation and optimization by neural networks Advances in Learning Theory: Methods, Models and Applications, pp.69-88, 2003. ,
Complexity of Gaussian-radial-basis networks approximating smooth functions, Journal of Complexity, vol.25, issue.1, pp.63-74, 2009. ,
DOI : 10.1016/j.jco.2008.08.001
URL : http://doi.org/10.1016/j.jco.2008.08.001
Remarques sur un résultat non publié de B. Maurey. In: Séminaire d'Analyse Fonctionnelle 1980-81, 1981. ,
A Simple Lemma on Greedy Approximation in Hilbert Space and Convergence Rates for Projection Pursuit Regression and Neural Network Training, The Annals of Statistics, vol.20, issue.1, pp.608-613, 1992. ,
DOI : 10.1214/aos/1176348546
A Sobolev-type upper bound for rates of approximation by linear combinations of Heaviside plane waves, Journal of Approximation Theory, vol.147, issue.1, pp.1-10, 2007. ,
DOI : 10.1016/j.jat.2006.12.009
