Adaptive electronic control of power-on upshifting in an autamatic transmission, US Patent, vol.282, issue.5, p.401, 1994. ,
Iterative optimization of the filling phase of wet clutches The 11th International Workshop on Advanced Motion Control, pp.94-99, 2010. ,
Modelling and predictive control of an electro-hydraulic actuated wet clutch for automatic transmission, 2010 IEEE International Symposium on Industrial Electronics, pp.256-261, 2010. ,
DOI : 10.1109/ISIE.2010.5637568
Multiobjective function optimization using nondominated sorting genetic algorithms, Evolutionary Computation, vol.3, pp.221-248, 1995. ,
DOI : 10.1162/evco.1994.2.3.221
URL : http://repository.ias.ac.in/9405/1/308.pdf
Multiobjective optimization and multiple constraint handling with evolutionary algorithms. I. A unified formulation, IEEE Transactions on Systems, Man, and Cybernetics - Part A: Systems and Humans, vol.28, issue.1, 1995. ,
DOI : 10.1109/3468.650319
URL : http://eprints.whiterose.ac.uk/79978/1/acse%20research%20report%20565.pdf
Discrete-time signal processing, Upper Saddle River, N.J, 1999. ,
The fast Fourier transform and its applications, Englewood Cliffs, N.J, 1988. ,
A multi-objective genetic local search algorithm and its application to flowshop scheduling, IEEE Transactions on Systems, Man and Cybernetics, Part C (Applications and Reviews), vol.28, issue.3, pp.392-403, 1998. ,
DOI : 10.1109/5326.704576
Genetic algorithms and engineering optimization, 2000. ,
DOI : 10.1002/9780470172261
On computing the inverse DFT, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.36, issue.2, pp.285-286, 1988. ,
DOI : 10.1109/29.1519
Digital signal processing, principles, algorithms, and applications (third edition), 1996. ,
