Survey over image thresholding techniques and quantitative performance evaluation, Journal of Electronic Imaging, vol.13, issue.1, pp.146-165, 2004. ,
A valley-seeking threshold selection technique, Computer Vision and Image Understanding, pp.55-65, 1992. ,
Automatic threshold selection based on histogram modes and a discriminant criterion, Machine Vision and Applications, pp.331-338, 1998. ,
DOI : 10.1007/s001380050083
Minimum error thresholding, Pattern Recognition, vol.19, issue.1, pp.41-47, 1986. ,
DOI : 10.1016/0031-3203(86)90030-0
Threshold selection based on cluster analysis, Pattern Recognition Letters, vol.25, issue.9, pp.1045-1050, 2004. ,
DOI : 10.1016/j.patrec.2004.03.001
A Threshold Selection Method from Gray-Level Histograms, IEEE Transactions on Systems, Man, and Cybernetics, vol.9, issue.1, pp.62-66, 1979. ,
DOI : 10.1109/TSMC.1979.4310076
Color Texture Segmentation Based on the Modal Energy of Deformable Surfaces, IEEE Transactions on Image Processing, vol.18, issue.7, pp.1613-1622, 2009. ,
DOI : 10.1109/TIP.2009.2018002
Fuzzy Energy-Based Active Contours, IEEE Transactions on Image Processing, vol.18, issue.12, pp.2747-2755, 2009. ,
DOI : 10.1109/TIP.2009.2030468
URL : https://hal.archives-ouvertes.fr/hal-01521387
Threshold selection using Renyi's entropy, Pattern Recognition, vol.30, issue.1, pp.71-84, 1997. ,
DOI : 10.1016/S0031-3203(96)00065-9
A new criterion for automatic multilevel thresholding, IEEE Transactions on Image Processing, vol.4, issue.3, pp.370-378, 1995. ,
Image thresholding by minimizing the measures of fuzziness, Pattern Recognition, vol.28, issue.1, pp.41-51, 1995. ,
DOI : 10.1016/0031-3203(94)E0043-K
Digital image thresholding, based on topological stable-state, Pattern Recognition, vol.29, issue.5, pp.829-843, 1996. ,
DOI : 10.1016/0031-3203(95)00126-3
Fuzzy partition of two-dimensional histogram and its application to thresholding, Pattern Recognition, vol.32, issue.5, pp.825-843, 1999. ,
DOI : 10.1016/S0031-3203(98)00080-6
A Robust Fuzzy Local Information C-Means Clustering Algorithm, IEEE Transactions on Image Processing, vol.19, issue.5, pp.1328-1337, 2010. ,
DOI : 10.1109/TIP.2010.2040763
Adaptive document image binarization, Pattern Recognition, vol.33, issue.2, pp.225-236, 2000. ,
DOI : 10.1016/S0031-3203(99)00055-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.98.880
A Hierarchical Clustering Based on Mutual Information Maximization, 2007 IEEE International Conference on Image Processing, pp.277-280, 2007. ,
DOI : 10.1109/ICIP.2007.4378945
Robust image hashing based on statistical invariance of dct coefficients, Journal of Information Hiding and Multimedia Signal Processing, vol.1, issue.4, pp.286-291, 2010. ,
The empirical mode decomposition and the Hilbert spectrum for nonlinear and non-stationary time series analysis, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.454, issue.1971, pp.903-995, 1998. ,
DOI : 10.1098/rspa.1998.0193
ENSEMBLE EMPIRICAL MODE DECOMPOSITION: A NOISE-ASSISTED DATA ANALYSIS METHOD, Advances in Adaptive Data Analysis, vol.46, issue.01, pp.1-41, 2009. ,
DOI : 10.1073/pnas.0701020104
Surface Extraction from Volumetric Images Using Deformable Meshes: A Comparative Study, Proceedings of 7th European Conference on Computer Vision, pp.350-364, 2002. ,
DOI : 10.1007/3-540-47977-5_23
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.11.2642
