411 Georgia Theocharopoulou and Konstantinos Giannakis Mood Classification Using Lyrics and Audio: A Case-Study in Greek Music, L. Kermanidis, and Ioannis Karydis XVI Table of Contents ? Part II ,
Christodoulakis Melodic String Matching via Interval Consolidation and Fragmentation, p.460 ,
470 Monika Dörfler Cutting Degree of Meanders, 480 A. Panayotopoulos and Panayiotis Vlamos Collective Intelligence in Video User's Activity . . . . . . . . . . . . . . . . . . . . . . . 490 ,
and Spyros Sioutas Data-Driven User Profiling to Support Web Adaptation through Cognitive Styles and Navigation Behavior, p.500 ,
Samaras Learning Vague Knowledge from Socially Generated Content in an Enterprise Framework, 510 Panos Alexopoulos, John Pavlopoulos, and Phivos Mylonas A Mobile-Based System for Context-Aware Music Recommendations, p.520 ,
Predicting Personality Traits from Spontaneous Modern Greek Text: Overcoming the Barriers 530 Vasileios Komianos Kermanidis An Implementation of the Digital Music Stand for Custom-Made On-Screen Music Manuscript Viewing, p.540 ,
Table of Contents ? Part II XVII First Workshop on Algorithms for Data and Text Mining in, Bioinformatics, 2012. ,
Ouzounis On Topic Categorization of PubMed Query Results, p.556 ,
and Evangelos Theodoridis Using an Atlas-Based Approach in the Analysis of Gene Expression Maps Obtained by Voxelation, p.566 ,
Smith, and Vasileios Megalooikonomou Parallel Implementation of the Wu-Manber Algorithm Using the OpenCL Framework, p.576 ,
Margaritis Querying Highly Similar Structured Sequences via Binary Encoding and Word Level Operations, p.584 ,
Pairwise Short-Read Alignment on Multi-core, p.593 ,
Patrinos, and Giannis Tzimas HINT-KB: The Human Interactome Knowledge Base 612 Konstantinos Theofilatos Likothanassis, and Seferina Mavroudi DISCO: A New Algorithm for Detecting 3D Protein Structure Similarity, 622 Nantia Iakovidou, Eleftherios Tiakas, and Konstantinos Tsichlas ncRNA-Class Web Tool: Non-coding RNA Feature Extraction and Pre-miRNA Classification Web Likothanassis, and Seferina Mavroudi XVIII Table of Contents ? Part II ,
651 Table of Contents ? Part I ,
Combination of M-Estimators and Neural Network Model to Analyze Inside/Outside Bark Tree Diameters, p.11 ,
Soraghan, and Lykourgos Petropoulakis Support Vector Machine Classification of Protein Sequences to Functional Families Based on Motif Selection, p.28 ,
Kermanidis, and Ioannis Mariolis Optimization-Genetic Algorithms ,
Andreou An Empirical Comparison of Several Recent Multi-objective Evolutionary Algorithms, p.48 ,
Julian Stoev, and Robin De Keyser Artificial Neural Networks A Representational MDL Framework for Improving Learning Power of Neural Network Formalisms, p.68 ,
Margaritis Improved POS-Tagging for Arabic by Combining Diverse Taggers, p.107 ,
117 Efthalia Karydi and Konstantinos G. Margaritis Experimental Identification of Pilot Response Using Measured Data from a Flight, Maytham Alabbas and Allan Ramsay Multithreaded Implementation of the Slope One Algorithm for, p.126 ,
Hosseinian-Far Conceptualization and Significance Study of a New Appliation CS, p.146 ,
Hybrid Method for Evaluating Biomass Suppliers ? Use of Intuitionistic Fuzzy Sets and Multi-Periodic Optimization, p.217 ,
Anthopoulos Classification Pattern Recognition A Neural Network for Spatial and Temporal Modeling of foF2 Data Based on Satellite Measurements, 224 Haris Haralambous and Harris Papadopoulos Detecting Glycosylations in Complex Samples, p.234 ,
244 Arman Mehrbakhsh and Alireza Khalilian Novel Matching Methods for Automatic Face Recognition Using SIFT, 254 Ladislav Lenc and Pavel Král Multi Agent Systems Exploring the Design Space of a Declarative Framework for Automated Negotiation: Initial Considerations, p.264 ,
Christos Pierrakeas, and Achilles Kameas XXII Table of Contents ? Part I ,
Isidoros Perikos, and Ioannis Hatzilygeroudis Effective Diagnostic Feedback for Online Multiple-Choice Questions, p.316 ,
Sin Wee Lee, and Fang Fang Cai Clustering A Fast Hybrid k -NN Classifier Based on Homogeneous Clusters 327 Stefanos Ougiaroglou and Georgios Evangelidis A Spatially-Constrained Normalized Gamma Process for Data Clustering, p.337 ,
Thieme Enhancing Clustering by Exploiting Complementary Data Modalities in the Medical Domain, Schultz, and Michael Krauthammer Extraction of Web Image Information: Semantic or Visual Cues, p.368 ,
374 Cosimo Birtolo, Davide Ronca, and Gianluca Aurilio Unsupervised Detection of Fibrosis in Microscopy Images Using Fractals and Fuzzy c-Means Clustering Plagianakos Image-Video Classification and Processing Image Threshold Selection Exploiting Empirical Mode Decomposition, 404 Zenonas Theodosiou and Nicolas Tsapatsoulis Table of Contents ? Part I XXIII ,
Anastassopoulos Engineering Applications of AI and Artificial Neural Networks Correlation between Seismic Intensity Parameters of HHT-Based Synthetic Seismic Accelerograms and Damage Indices of Buildings, p.425 ,
Jovic A New Approach to High Impedance Fault Detection Based on Correlation Functions, 453 Najmeh Faridnia, Haidar Samet, and Babak Doostani Dezfuli Network Selection in a Virtual Network Operator Environment . . . . . . . . 463 Ioannis Chamodrakas and Drakoulis Martakos Position and Velocity Predictions of the Piston in a Wet Clutch System during Engagement by Using a Neural Network Modeling, p.474 ,
Wim Symens, Julian Stoev, and Robin De Keyser Uniform Asymptotic Stability and Global Asymptotic Stability for Time-Delay Hopfield Neural Networks, p.483 ,
