A Practical Non-Linear Parameterization of the BRDF Manifold
Une parametrisation non linéaire mais versatile du manifolde des BRDFs
Real-world reflectance data can be used to improve the realism of synthesized images,
albeit with many challenges: memory footprints can be large, profiles are limited to a finite (usually
small) set of materials and rendering with measured data can be costly. Since the observation
space (number of reflectance measurements) is usually much larger than the underlying space of
real-world reflectance profiles, a typical optimisation strategy identifies principal components in
the data to directly render from compressed representations of the measurements. We directly
learn an underlying low-dimensional non-linear reflectance manifold amenable to rapid exploration
and rendering of the space of real-world materials. We show that interpolated materials can be
expressed as linear combinations of the measured data, despite lying on a non-linear manifold.
This allows us to efficiently interpolate, extrapolate and render directly from the manifold. We
apply a Gaussian process latent variable model to represent the reflectance manifold, demonstrating
its utility in the context of high-performance and realistic rendering with materials that are
interpolations of acquired BRDFs (from the popular MERL dataset).
RR-9069-1.pdf (8.87 Mo)
Télécharger le fichier
Format : Figure, Image
