Extending the Service Life Span of Ageing Oil and Gas Offshore Production Facilities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sushil Palkar
  • Fonction : Auteur
  • PersonId : 1008352
Tore Markeset
  • Fonction : Auteur
  • PersonId : 1008353
A large number of facilities and parts of the infrastructure of offshore oil and gas reservoirs worldwide are approaching or have exceeded their original design life. The petroleum fields are still producing substantial levels of hydrocarbons which are recoverable and profitable if the field’s lifetime is extended. Thus, parts of this infrastructure are being considered for use beyond their planned design life. However, focusing on safety considerations, the condition of systems, structures and components (SSC) may not be acceptable for extended operation. The purpose of this paper is to discuss guidelines for assessing life extension in order to ensure the technical and operational integrity of these ageing facilities. The objective is to highlight those mechanisms by which the installation is degraded physically and functionally including the human factors and organizational issues. This documentation on ageing mechanisms will provide the foundation for a service lifetime extension process.
978-3-642-33980-6_25_Chapter.pdf (165.89 Ko) Télécharger le fichier
hal-01524184 , version 1 (17-05-2017)
Paternité
Sushil Palkar, Tore Markeset. Extending the Service Life Span of Ageing Oil and Gas Offshore Production Facilities. International Conference on Advances in Production Management Systems (APMS), Sep 2011, Stavanger, Norway. pp.213-221, ⟨10.1007/978-3-642-33980-6_25⟩. ⟨hal-01524184⟩
89 Consultations
782 Téléchargements
