Identifying Challenges in the Maintenance of Subsea Petroleum Production Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tore Markeset
  • Fonction : Auteur
  • PersonId : 1008353
Maintenance strategies for subsea oil and gas production installations entail the use of specialized equipment and vessels to carry out subsea interventions. The costs for carrying out preventive maintenance are significantly lower compared to the costs of unpredicted failures where in some cases it is necessary to reduce or stop the oil production. Based on a literature review and inputs from industrial experts, this paper discusses maintenance challenges for subsea oil and gas facilities.
978-3-642-33980-6_29_Chapter.pdf (169.7 Ko) Télécharger le fichier
hal-01524229 , version 1 (17-05-2017)
Paternité
Jorge Moreno-Trejo, Tore Markeset. Identifying Challenges in the Maintenance of Subsea Petroleum Production Systems. International Conference on Advances in Production Management Systems (APMS), Sep 2011, Stavanger, Norway. pp.251-259, ⟨10.1007/978-3-642-33980-6_29⟩. ⟨hal-01524229⟩
80 Consultations
1425 Téléchargements
