Shape from sensors: Curve networks on surfaces from 3D orientations - Archive ouverte HAL Access content directly
Journal Articles Computers and Graphics Year : 2017
(1, 2) , (1) , (3) , (2)
1
2
3
We present a novel framework for acquisition and reconstruction of 3D curves using orientations provided by inertial sensors. While the idea of sensor shape reconstruction is not new, we present the first method for creating well-connected networks with cell complex topology using only orientation and distance measurements and a set of user- defined constraints. By working directly with orientations, our method robustly resolves problems arising from data inconsistency and sensor noise. Although originally designed for reconstruction of physical shapes, the framework can be used for “sketching” new shapes directly in 3D space. We test the performance of the method using two types of acquisition devices: a standard smartphone, and a custom-made device.
shape-sensors.pdf (9.89 Mo) Télécharger le fichier
Format : Figure, Image
Dates and versions
hal-01524740 , version 1 (18-05-2017)
hal-01524740 , version 2 (19-05-2017)
Identifiers
Cite
Tibor Stanko, Stefanie Hahmann, Georges-Pierre Bonneau, Nathalie Saguin-Sprynski. Shape from sensors: Curve networks on surfaces from 3D orientations. Computers and Graphics, 2017, Special Issue on SMI 2017, 66, pp.74-84. ⟨10.1016/j.cag.2017.05.013⟩. ⟨hal-01524740v2⟩
619 View
461 Download
Share
