Comparing high dimensional pairs of partitions with the Coclustering Adjusted Rand Index - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
The popular Adjusted Rand Index (ARI) is extended to the task of simultaneous clustering of the rows and columns of a given matrix. This new index called Coclustering Adjusted Rand Index (CARI) remains convenient and competitive facing other indices. Indeed, partitions with high numbers of clusters can be considered and it does not require any convention when the numbers of clusters in partitions are different. Experiments on simulated partitions are presented and the performance of this index to measure the agreement between two pairs of partitions is assessed. Comparison with other indices is discussed.
article_CARI.pdf (218.56 Ko) Télécharger le fichier
hal-01524832 , version 1 (18-05-2017)
hal-01524832 , version 2 (21-05-2017)
hal-01524832 , version 3 (31-05-2017)
hal-01524832 , version 4 (14-01-2019)
hal-01524832 , version 5 (21-11-2020)
  • HAL Id : hal-01524832 , version 2
Valérie Robert, Yann Vasseur. Comparing high dimensional pairs of partitions with the Coclustering Adjusted Rand Index. 2017. ⟨hal-01524832v2⟩
1041 Consultations
1490 Téléchargements
