Metacognition in computation: A selected research review, Artificial Intelligence, vol.169, issue.2, pp.104-141, 2005. ,
DOI : 10.1016/j.artint.2005.10.009
URL : http://doi.org/10.1016/j.artint.2005.10.009
Extending introspective learning from self-models ,
A modelbased approach to the construction of adaptive case-based planning systems, Proceedings of the DARPA Case-Based Reasoning Workshop, pp.215-224, 1991. ,
Introspective multistrategy learning: On the construction of learning strategies, Artificial Intelligence, vol.112, issue.1-2, pp.1-55, 1999. ,
DOI : 10.1016/S0004-3702(99)00047-8
Using Introspective Reasoning to Refine Indexing, Proceedings of the 14th International Joint Conference on Artificial Intelligence, pp.391-397, 1995. ,
Changing the Viewpoint: Re-Indexing by Introspective Question, Proceedings of the 16th Annual Conference of the Cognitive Science Society, pp.381-386, 1995. ,
Learning to Improve Case Adaptation by Introspective Reasoning and CBR. Case-Based Reasoning Research and Development, Proceedings of the 1st International Conference on Case-Based Reasoning, pp.229-240, 1995. ,
DOI : 10.1007/3-540-60598-3_21
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.49.1233
Feature Weight Maintenance in Case Bases Using Introspective Learning, Journal of Intelligent Information Systems, vol.16, issue.2, pp.95-116, 2001. ,
DOI : 10.1023/A:1011208900462
Introspective Learning to Build Case-Based Reasoning (CBR) Knowledge Containers, MLDM, vol.2003, pp.1-6 ,
DOI : 10.1007/3-540-45065-3_1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.97.3840
Measures of Solution Accuracy in Case-Based Reasoning Systems, Proceedings of the 7th European Conference on Case-Based Reasoning, number 3155 in Lecture Notes in Artificial Intelligence, pp.106-118, 2004. ,
DOI : 10.1007/978-3-540-28631-8_9
Using Introspective Reasoning to Improve CBR System Performance, pp.21-28, 2008. ,
DOI : 10.7551/mitpress/9780262014809.003.0011
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.554.5944
Integrated Introspective Case-Based Reasoning for Intelligent Tutoring Systems. Association for the Advancement of Artificial Intelligence, p.2007 ,
Enhancing Case Adaptation with Introspective Reasoning and Web Mining, IJCAI, vol.2011, pp.2680-2685, 2011. ,
Transfer Learning. Handbook of Research on Machine Learning Applications and Trends: Algorithms, Methods, and Techniques, pp.242-264, 2010. ,
Learning relational skills for inductive transfer in relational reinforcement learning, International Conference on Inductive Logic Programming, 2007. ,
Graph-Based Domain Mapping for Transfer Learning in General Games, European Conference on Machine Learning, 2007. ,
DOI : 10.1007/978-3-540-74958-5_20
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.79.5455
Knowledge transfer with a multiresolution ensemble learning of classifiers, ICML Workshop on Structural Knowledge Transfer for Machine, 2006. ,
Task similarity measures for transfer in reinforcement works learning task libraries, IEEE International Joint Conference on Neural Net, 2005. ,
DOI : 10.1109/ijcnn.2005.1555955
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.81.1753
Task Clustering and Gating for Bayesian Multitask Learning, J. Machine Learning Research, vol.4, pp.83-99, 2003. ,
An Algorithm for Transfer Learning in a Heterogeneous Environment, Proc European Conf. Machine Learning and Knowledge Discovery in Databases (ECML/PKDD '08), pp.71-85, 2008. ,
DOI : 10.1007/978-3-540-87479-9_23
A Survey on Transfer Learning, IEEE Trans. Knowl. Data Eng, vol.22, issue.10, pp.1345-1359, 2010. ,
Correcting Sample Selection Bias by Unlabeled Data, Proc. 19th Ann. Conf. Neural Information Processing Systems, 2006. ,
Direct Importance Estimation with Model Selection and its Application to Covariate Shift Adaptation, Proc. 20th Ann. Conf. Neural Information Processing Systems, 2008. ,
DOI : 10.1007/s10463-008-0197-x
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.592.3866
Representation and learning in information retrieval, Ph.D. Dissertation, 1992. ,
Transferring Naive Bayes Classifiers for Text Classification, Proc. 22nd Assoc. for the Advancement of Artificial Intelligence (AAAI) Conf. Artificial Intelligence, pp.540-545, 2007. ,
Co-clustering based classification for out-of-domain documents, Proceedings of the 13th ACM SIGKDD international conference on Knowledge discovery and data mining , KDD '07, pp.210-219, 2007. ,
DOI : 10.1145/1281192.1281218
Spectral domain-transfer learning, Proceeding of the 14th ACM SIGKDD international conference on Knowledge discovery and data mining, KDD 08, pp.488-496, 2008. ,
DOI : 10.1145/1401890.1401951
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.141.1551
Crossdomain Learning from Multiple Sources: A Consensus Regularization Perspective, IEEE Transactions on Knowledge and Data Engineering, issue.12, pp.22-1664, 2010. ,
Case-Based Introspective Learning, Proceedings of the Fourth IEEE International Conference on Cognitive Informatics, 2005. ,
A Research on Introspective Learning Based on CBR, International Journal of Advanced Intelligence, vol.3, issue.1, pp.147-157, 2011. ,
Domain Adaptation for Statistical Classifiers, J. Artificial Intelligence Research, vol.26, pp.101-126, 2006. ,
