Diagnosis of Internetware Systems Using Dynamic Description Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper proposes a kind of multi-agent based internetware system architecture, and introduces a diagnoser that can perform on-line diagnosis by observing the behaviors of it. This diagnoser brings semantic description to the procedure of states conversation of the system to be diagnosed by using dynamic description logic, which makes it possible to make use of more knowledge to analyze the failure further.
978-3-642-32891-6_35_Chapter.pdf (375.03 Ko) Télécharger le fichier
hal-01524954 , version 1 (19-05-2017)
Paternité
Kun Yang, Weiqun Cui, Junheng Teng, Chenzhe Hang. Diagnosis of Internetware Systems Using Dynamic Description Logic. 7th International Conference on Intelligent Information Processing (IIP), Oct 2012, Guilin, China. pp.276-285, ⟨10.1007/978-3-642-32891-6_35⟩. ⟨hal-01524954⟩
45 Consultations
51 Téléchargements
