A Representation Model of Geometrical Tolerances Based on First Order Logic - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
(1) , (1) , (1) , (2)
1
2
Tolerance representation models are used to specify tolerance types and explain semantics of tolerances for nominal geometry parts. To well explain semantics of geometrical tolerances, a representation model of geometrical tolerances based on First Order Logic (FOL) is presented in this paper. We first investigate the classifications of feature variations and give the FOL representations of them based on these classifications. Next, based on the above representations, we present a FOL representation model of geometrical tolerances. Furthermore, we demonstrate the effectiveness of the representation model by specifying geometrical tolerance types in an example.
978-3-642-32891-6_30_Chapter.pdf (261.92 Ko) Télécharger le fichier
Dates and versions
hal-01524962 , version 1 (19-05-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Yuchu Qin, Yanru Zhong, Liang Chang, Meifa Huang. A Representation Model of Geometrical Tolerances Based on First Order Logic. 7th International Conference on Intelligent Information Processing (IIP), Oct 2012, Guilin, China. pp.234-239, ⟨10.1007/978-3-642-32891-6_30⟩. ⟨hal-01524962⟩
44 View
102 Download
Share
