Analysis of technical documents: The RE- DRAW system, pp.385-402, 1992. ,
Extraction,layout analysis and classification of diagrams in PDF documents, Seventh International Conference on Document Analysis and Recognition, 2003. Proceedings., pp.1007-1014, 2003. ,
DOI : 10.1109/ICDAR.2003.1227811
A Diagram Is Worth A Dozen Images. arXiv preprint, 2016. ,
DOI : 10.1007/978-3-319-46493-0_15
URL : http://arxiv.org/abs/1603.07396
Constructing a mental representation from an abstract technical diagram, Learning and Instruction, vol.3, issue.3, pp.157-179, 1993. ,
DOI : 10.1016/0959-4752(93)90002-H
From data mining to knowledge discovery in databases, AI magazine, vol.17, issue.3, p.37, 1996. ,
Retrieval of technical drawings in DXF format-concepts and problems, Citeseer, pp.213-220, 2007. ,
Knowledge extraction from medium voltage load diagrams to support the definition of electrical tariffs, Engineering Intelligent Systems for Electrical Engineering and Communications, vol.15, issue.3, pp.143-149, 2007. ,
Encoding sequential structure in simple recurrent networks. Tech. rep., DTIC Document (1989) 10. Hees, J.: SciPy Hierarchical Clustering and Dendrogram Tu- torial, 2015. ,
Learning the structure of event sequences., Journal of Experimental Psychology: General, vol.120, issue.3, p.235, 1991. ,
DOI : 10.1037/0096-3445.120.3.235
