Linear Solution to Attitude Determination from Vector Observations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
This paper deals with the attitude determination problem where the effect of weights is ignored. In this way, the developed method is named as the Sub-Optimal Linear Estimator of Quaternion (SOLEQ). The theory is established based on a recent publication and the two-vector matrix multiplications are decomposed with the Eigenvalue Factorization. Some analytical results are proved and given which provides the audience with a brand new viewpoint of the attitude determination and its evolution inside. With the derivations of two-vector case, the n-vector cased is then naturally formed. Simulations are carried out showing the accuracy and time consumption of the proposed SOLEQ, compared with representative ones. The algorithm is then implemented using C++ programming language on the designed hardware with 3-axis accelerometer, 3-axis magnetometer, giving the effectiveness validation of the SOLEQ in real-world applications.
bare_jrnl.pdf (2.66 Mo) Télécharger le fichier
hal-01525603 , version 1 (22-05-2017)
hal-01525603 , version 2 (20-07-2017)
hal-01525603 , version 3 (09-08-2017)
hal-01525603 , version 4 (11-12-2017)
Paternité
  • HAL Id : hal-01525603 , version 1
Jin Wu, Zebo Zhou, Jinling Wang, Hassen Fourati. Linear Solution to Attitude Determination from Vector Observations. 2017. ⟨hal-01525603v1⟩
1061 Consultations
854 Téléchargements
