Optimal, Recursive and Suboptimal Linear Solutions to Attitude Determination from Vector Observations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
This paper deals with the optimal attitude determination problem and its sub-optimal and time-varying recursive variants. The developed methods are named as the Optimal Linear Estimator of Quaternion (OLEQ), Suboptimal-OLEQ (SOLEQ) and Recursive-OLEQ (ROLEQ). The theory is established based on our previous contributions and the multivector matrix multiplications are decomposed with the eigenvalue factorization. Some analytical results are proved and given which provides the audience with a brand new viewpoint of the attitude determination and its evolution inside. With the derivations of two-vector case, the n-vector cased is then naturally formed. Simulations are carried out showing the advantages of accuracy, robustness and time consumption of the proposed OLEQs, compared with representative methods. The algorithms are then implemented using C++ programming language on the designed hardware with 3-axis accelerometer, 3-axis magnetometer, giving the effectiveness validation of them in real-world applications.
bare_jrnl.pdf (4.13 Mo) Télécharger le fichier
hal-01525603 , version 1 (22-05-2017)
hal-01525603 , version 2 (20-07-2017)
hal-01525603 , version 3 (09-08-2017)
hal-01525603 , version 4 (11-12-2017)
Paternité
  • HAL Id : hal-01525603 , version 2
Jin Wu, Zebo Zhou, Jinling Wang, Hassen Fourati, Chang Lubin. Optimal, Recursive and Suboptimal Linear Solutions to Attitude Determination from Vector Observations. 2017. ⟨hal-01525603v2⟩
1061 Consultations
854 Téléchargements
