Behavioural semantics for asynchronous components
Software components are a valuable programming abstraction that enables a compositional design of complex applications. In distributed systems, components can also be used to provide an abstraction of locations: each component is a unit of deployment that can be placed on a different machine. In this article, we consider this kind of distributed components that are additionally loosely coupled and communicate by asynchronous invocations. Components also provide a convenient abstraction for verifying the correct behaviour of systems: they provide structuring entities easing the correctness verification. This article provides a formal background for the generation of behavioural semantics for asynchronous components. It expresses the semantics of hierarchical distributed components communicating asynchronously by requests, futures, and replies; this semantics is provided using the pNet intermediate language. This article both demonstrates the expressiveness of the pNet model and formally specifies the complete process of the generation of a behavioural model for a distributed component system. The purpose of our be-havioural semantics is to allow for verification both by finite instantiation and model-checking, and by techniques for infinite systems.
