Improved determination of the Higgs mass in the MSSM with heavy superpartners - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Physical Journal C: Particles and Fields Année : 2017
We present several advances in the effective field theory calculation of the Higgs mass in MSSM scenarios with heavy superparticles. In particular, we compute the dominant two-loop threshold corrections to the quartic Higgs coupling for generic values of the relevant SUSY-breaking parameters, including all contributions controlled by the strong gauge coupling and by the third-family Yukawa couplings. We also study the effects of a representative subset of dimension-six operators in the effective theory valid below the SUSY scale. Our results will allow for an improved determination of the Higgs mass and of the associated theoretical uncertainty.
art_10.1140_epjc_s10052-017-4885-7.pdf (681.26 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-01526214 , version 1 (22-05-2017)
Paternité
Emanuele Bagnaschi, Javier Pardo Vega, Pietro Slavich. Improved determination of the Higgs mass in the MSSM with heavy superpartners. European Physical Journal C: Particles and Fields, 2017, 77 (5), pp.334. ⟨10.1140/epjc/s10052-017-4885-7⟩. ⟨hal-01526214⟩
183 Consultations
159 Téléchargements
