High-efficiency single etch step surface grating couplers engineered by subwavelength structured metamaterials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We report our recent developments of high-efficiency fiber-chip surface grating couplers engineered by subwavelength grating structuration. The intriguing technological concept of subwavelength grating index engineering provides extraordinary degree of freedom in designing and fabricating high-performance optical coupling interfaces for sub-micrometric silicon-on-insulator technology. We present an overview of various demonstrations of high-efficiency surface grating couplers, particularly develop for silicon photonics applications in the near-infrared spectral range (near 1.3 μm and 1.55 μm wavelengths) such as datacom and telecom optical interconnects.
META2016_DanielBenedikovic.pdf (336.2 Ko) Télécharger le fichier
hal-01527366 , version 1 (24-05-2017)
  • HAL Id : hal-01527366 , version 1
D Benedikovic, C Alonso-Ramos, L Vivien, P Cheben, J H Schmid, et al.. High-efficiency single etch step surface grating couplers engineered by subwavelength structured metamaterials. 7th International Conference on Metamaterials, Photonic Crystals and Plasmonics (META 2016), Jul 2016, Malaga, Spain. ⟨hal-01527366⟩
605 Consultations
120 Téléchargements
