Query Processing Using Negative and Temporal Tuples in Stream Query Engines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marcin Gorawski
  • Fonction : Auteur
  • PersonId : 1008825
Aleksander Chrószcz
  • Fonction : Auteur
  • PersonId : 1008826
In this paper, we analyze how stream monotonicity classification can be adopted for the introduced developed model, which processes both temporal and negative events. As we show, information about stream monotonicity can be easily used to optimize individual stream operators as well as a full query plan. Comparing our stream engine with such engines as CEDR, STREAM and PIPES we demonstrate how a primary key constraint can be used in different types of the developed stream schemes. We implemented all of the above techniques in StreamAPAS.
978-3-642-28038-2_6_Chapter.pdf (1.5 Mo) Télécharger le fichier
hal-01527387 , version 1 (24-05-2017)
Paternité
Marcin Gorawski, Aleksander Chrószcz. Query Processing Using Negative and Temporal Tuples in Stream Query Engines. 4th Central and East European Conference on Software Engineering Techniques (CEESET), Oct 2009, Krakow, Poland. pp.70-83, ⟨10.1007/978-3-642-28038-2_6⟩. ⟨hal-01527387⟩
38 Consultations
74 Téléchargements
