Abstract : Scalable Store of Objects (SSO) should allow for storing and maintaining a huge number of objects distributed over many nodes of a network. RP*N is a structure which belongs to a family of order-preserving, Range Partitioning Scalable Distributed Data Structures (RP* SDDS). The architectures of SDDS were designed to store records. Different structures of objects and complicated dependences between objects are the cause that a new architecture for RP* is needed. The paper describes a new object-oriented version of RP*N architecture and its implementation for Java objects. This version can be used in a fast and scalable store of Java objects. Performance of the implementation is evaluated and compared with serialization of objects on a disk and storing objects as a main-memory collection.
https://hal.inria.fr/hal-01527389 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, May 24, 2017 - 12:48:59 PM Last modification on : Wednesday, May 24, 2017 - 2:18:01 PM Long-term archiving on: : Monday, August 28, 2017 - 12:48:01 AM
Mariusz Bedla, Krzysztof Sapiecha. Scalable Store of Java Objects Using Range Partitioning. 4th Central and East European Conference on Software Engineering Techniques (CEESET), Oct 2009, Krakow, Poland. pp.84-93, ⟨10.1007/978-3-642-28038-2_7⟩. ⟨hal-01527389⟩
