Does code decay? Assessing the evidence from change management data, IEEE Transactions on Software Engineering, vol.27, issue.1, pp.1-12, 2001. ,
DOI : 10.1109/32.895984
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.368.141
Source Code Analysis: A Road Map, Future of Software Engineering (FOSE '07), pp.104-119, 2007. ,
DOI : 10.1109/FOSE.2007.27
A survey of software refactoring, IEEE Transactions on Software Engineering, vol.30, issue.2, pp.126-139, 2004. ,
DOI : 10.1109/TSE.2004.1265817
Reengineering legacy systems for distributed environments, Journal of Systems and Software, vol.64, issue.1, pp.37-55, 2002. ,
DOI : 10.1016/S0164-1212(02)00020-1
Search-based determination of refactorings for improving the class structure of object-oriented systems, Proceedings of the 8th annual conference on Genetic and evolutionary computation , GECCO '06, pp.1909-1916, 2006. ,
DOI : 10.1145/1143997.1144315
Refactoring: Improving the Design of Existing Code, 1999. ,
DOI : 10.1007/3-540-45672-4_31
Transformation of Legacy Software into Client/Server Applications through Pattern-Based Rearchitecturing, 2008 32nd Annual IEEE International Computer Software and Applications Conference, pp.303-310, 2008. ,
DOI : 10.1109/COMPSAC.2008.158
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.596.4300
Pattern-Based Refactoring of Legacy Software Systems, Proc. of the 11th International Conference on Enterprise Information Systems (ICEIS), pp.78-89, 2009. ,
DOI : 10.1007/978-3-642-01347-8_7
Object-Oriented Metrics in Practice, 2006. ,
Object-Oriented Software Engineering: Measuring and Controlling the Development Process, Proc. of the 4th International Conference on Software Quality (ASQC), 1994. ,
A Case Study on the Impact of Refactoring on Quality and Productivity in an Agile Team, 2nd IFIP TC 2 Central and East European Conf. on Software Engineering Techniques (CEE-SET), Revised Selected Papers, pp.252-266, 2007. ,
DOI : 10.1109/CSMR.2001.914965
Search-based Refactoring for Software Maintenance, Journal of Systems and Software, vol.81, issue.4, pp.502-516, 2008. ,
Improving design quality using meta-pattern transformations: a metric-based approach, Journal of Software Maintenance and Evolution: Research and Practice, vol.16, issue.45, pp.4-5, 2004. ,
DOI : 10.1002/smr.299
Anti-Patterns: Refactoring Software, Architectures, and Projects in Crisis, 1998. ,
Points-To Analysis, 2005. ,
Dimensions of Precision in Reference Analysis of Object-Oriented Programming Languages, Proc. of the 12th International Conf. on Compiler Construction, pp.126-137, 2003. ,
DOI : 10.1007/3-540-36579-6_10
