New interface
Conference papers
A new on-line method for scheduling independent tasks
Giorgio Lucarelli 1, 2 Fernando Machado Mendonca 1, 2 Denis Trystram 1, 2
1 DATAMOVE - Data Aware Large Scale Computing
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
Abstract : We present a new method for scheduling independent tasks on a parallel machine composed of identical processors. This problem has been studied extensively for a long time with many variants. We are interested here in designing a generic algorithm in the on-line non-preemptive setting whose performance is good for various objectives. The basic idea of this algorithm is to detect some problematic tasks that are responsible for the delay of other shorter tasks. Then the former tasks are redirected to be executed in a dedicated part of the machine. We show through an extensive experimental campaign that this method is effective and in most cases is closer to some standard lower bounds than the base-line method for the problem.
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01527746
Contributor : Lucarelli Giorgio Connect in order to contact the contributor
Submitted on : Thursday, June 15, 2017 - 9:16:00 AM
Last modification on : Wednesday, July 6, 2022 - 4:22:52 AM
Long-term archiving on: : Tuesday, December 12, 2017 - 2:02:28 PM
File
C23.pdf
Identifiers
  • HAL Id : hal-01527746, version 1
Citation
Giorgio Lucarelli, Fernando Machado Mendonca, Denis Trystram. A new on-line method for scheduling independent tasks. 17th IEEE/ACM International Symposium on Cluster, Cloud and Grid Computing (CCGRID 2017), May 2017, Madrid, Spain. ⟨hal-01527746⟩
Share
Metrics
Record views
184
Files downloads
310
