Homogenized double porosity models for poro-elastic media with interfacial flow barrier, Math. Bohem, vol.136, p.357365, 2011. ,
Homogenization of a dual-permeability problem in two-component media with imperfect contact, Applications of Mathematics, vol.60, issue.2, pp.185-196, 2015. ,
DOI : 10.1007/s10492-015-0090-x
Homogenization and Two-Scale Convergence, SIAM Journal on Mathematical Analysis, vol.23, issue.6, pp.1482-1518, 1992. ,
DOI : 10.1137/0523084
URL : https://hal.archives-ouvertes.fr/hal-01111805
EVOLUTION AND MEMORY EFFECTS IN THE HOMOGENIZATION LIMIT FOR ELECTRICAL CONDUCTION IN BIOLOGICAL TISSUES, Mathematical Models and Methods in Applied Sciences, vol.127, issue.09, pp.1261-1295, 2004. ,
DOI : 10.1080/00036819708840562
A hierarchy of models for the electrical conduction in biological tissues via two-scale convergence: The nonlinear case, Differ, Integral Equations, vol.26, pp.9-10, 2013. ,
Derivation of the Double Porosity Model of Single Phase Flow via Homogenization Theory, SIAM Journal on Mathematical Analysis, vol.21, issue.4, pp.823-836, 1990. ,
DOI : 10.1137/0521046
Homogenization of Coupled Phenomena in Heterogenous Media, 2010. ,
DOI : 10.1002/9780470612033
Macroscopic modelling of heat transfer in composites with interfacial thermal barrier, International Journal of Heat and Mass Transfer, vol.37, issue.18, pp.2885-2892, 1994. ,
DOI : 10.1016/0017-9310(94)90342-5
Basic concepts in the theory of seepage of homogeneous liquids in fissured rocks [strata], Journal of Applied Mathematics and Mechanics, vol.24, issue.5, pp.852-864, 1960. ,
DOI : 10.1016/0021-8928(60)90107-6
Imperfect soft and stiff interfaces in two-dimensional elasticity, Mechanics of Materials, vol.33, issue.6, pp.309-324, 2001. ,
DOI : 10.1016/S0167-6636(01)00055-2
A DRIFT???DIFFUSION???REACTION MODEL FOR EXCITONIC PHOTOVOLTAIC BILAYERS: ASYMPTOTIC ANALYSIS AND A 2D HDG FINITE ELEMENT SCHEME, Mathematical Models and Methods in Applied Sciences, vol.1, issue.05, pp.839-872, 2013. ,
DOI : 10.1016/S0009-2614(98)01277-9
Homogenization of a Thermal Problem with Flux Jump, Networks and Heterogeneous Media, to appear ,
On the Homogenization of a Diffusion Problem with Flux Jump ,
The Periodic Unfolding Method in Domains with Holes, SIAM Journal on Mathematical Analysis, vol.44, issue.2, pp.718-760, 2012. ,
DOI : 10.1137/100817942
URL : https://hal.archives-ouvertes.fr/hal-00591632
The Periodic Unfolding Method in Homogenization, SIAM Journal on Mathematical Analysis, vol.40, issue.4, pp.1585-1620, 2008. ,
DOI : 10.1137/080713148
URL : https://hal.archives-ouvertes.fr/hal-00693080
The periodic unfolding method in perforated domains, Portugaliae Math, vol.63, issue.4, pp.467-496, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00439097
Asymptotic behavior of elliptic problems in perforated domains with nonlinear boundary conditions, Asymptot. Anal, vol.53, pp.209-235, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00439100
Homogenization and correctors of a class of elliptic problems in perforated domains, Asymptot. Anal, vol.92, pp.1-43, 2015. ,
Homogenization of diffusion problems with a nonlinear interfacial resistance, Nonlinear Differ, Equ. Appl ,
The periodic unfolding method for a class of imperfect transmission problems, Journal of Mathematical Sciences, vol.54, issue.3, pp.6-891, 2011. ,
DOI : 10.1051/m2an/2010008
HOMOGENIZATION OF TWO HEAT CONDUCTORS WITH AN INTERFACIAL CONTACT RESISTANCE, Analysis and Applications, vol.90, issue.03, pp.247-273, 2004. ,
DOI : 10.1098/rspa.1996.0018
Homogenization of an elastic double-porosity medium with imperfect interface via the periodic unfolding method, Boundary Value Problems, p.265, 2013. ,
Model of diffusion in partially fissured media, Zeitschrift f??r angewandte Mathematik und Physik, vol.53, issue.6, pp.1052-1059, 2002. ,
DOI : 10.1007/PL00013849
Microstructure models for composites with imperfect interface via the periodic unfolding method, Asymptot. Anal, vol.89, issue.12, pp.111-122, 2014. ,
Homogenization of a thermoelasticity model for a composite with imperfect interface, Bull, Math. Soc. Sci. Math. Roumanie, vol.2, issue.106, pp.58-147, 2015. ,
Homogenization results for a dynamic coupled thermoelasticity problem, Romanian Reports in Physics, 2016. ,
A discontinuous Poisson?Boltzmann equation with interfacial transfer: homogenisation and residual error estimate, preprint, 2014. ,
Heat transfer models for two-component media with interfacial jump, Applicable Analysis, vol.13, issue.2, 2015. ,
DOI : 10.1016/0022-247X(79)90211-7
URL : https://hal.archives-ouvertes.fr/hal-01469518
Thin interphase/imperfect interface in elasticity with application to coated fiber composites, Journal of the Mechanics and Physics of Solids, vol.50, issue.12, pp.2509-2537, 2002. ,
DOI : 10.1016/S0022-5096(02)00050-9
Homogenization for heat transfer in polycrystals with interfacial resistances, Applicable Analysis, vol.127, issue.3-4, pp.403-424, 2000. ,
DOI : 10.1137/0520043
Pattern formation in reverse smouldering combustion: a homogenization approach, Combustion Theory and Modelling, pp.185-223, 2013. ,
Homogenization of heat transfer process in composite materials, JEPE, vol.1, pp.175-188, 2015. ,
Homogenization of a two-component composite with interfacial thermal barrier, Adv. Math. Sci. Appl, vol.13, issue.1, pp.43-63, 2003. ,
Homogenization cases of heat transfer in structures with interfacial barriers, Bulletin Mathématique de la Société des Sciences Mathématiques de Roumanie, pp.463-473, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01283642
Heat conduction through a first-order jump interface, New Trends in Continuum Mechanics, Theta Series in Advanced Mathematics, pp.225-230, 2005. ,
Diffusion in an intermediate model of fractured porous media, Bulletin Scientifique, Mathématiques et Informatique, vol.10, pp.99-106, 2004. ,
On the problem of the process of propagation of heat in heterogeneous media, Izv. Akad. Nauk SSSR Ser. Geogr, vol.1, 1948. ,
Microstructure Models of Porous Media, Homogenization and Porous Media, pp.183-202, 1997. ,
Multiscale analysis of diffusion processes in composite media, Computers & Mathematics with Applications, vol.66, issue.9, pp.1573-1580, 2013. ,
DOI : 10.1016/j.camwa.2012.12.003
Multiscale modeling of heat transfer in composite materials, Romanian Journal of Physics, vol.58, issue.9-10, pp.1418-1427, 2013. ,
Multiscale analysis in nonlinear thermal diffusion problems in composite structures , Cent. Eur, J. Phys, vol.8, pp.555-561, 2010. ,
