Monotone Simultaneous Paths Embeddings in $\mathbb{R}^d$
We study the following problem: Given $k$ paths that share the same vertex set, is there a simultaneous geometric embedding of these paths such that each individual drawing is monotone in some direction? We prove that for any dimension $d\geq 2$, there is a set of $d + 1$ paths that does not admit a monotone simultaneous geometric embedding.
dmtcs.pdf (593.53 Ko)
Télécharger le fichier
Format : Figure, Image
