ActorSpaces: An open distributed programming paradigm, Proceedings of the 8th ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming, PPOPP 1993, pp.23-32, 1993. ,
DOI : 10.1145/155332.155335
ACTORS ? A Model of Concurrent Computation in Distributed Systems series in artificial intelligence, 1986. ,
Customizaton and compositon of distributed objects: Middleware abstractions for policy management, SIGSOFT FSE, pp.1-9, 1998. ,
Unreliable failure detectors for reliable distributed systems, J. ACM, vol.43, pp.225-267, 1996. ,
Transactors: a programming model for maintaining globally consistent distributed state in unreliable environments, Proceedings of the 32nd ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, POPL 2005, pp.195-208, 2005. ,
Coordinating distributed objects -an actor-based approach to synchronization, 1996. ,
A Language Framework for Multi-Object Coordination, ECOOP'93 -Object-Oriented Programming, 7th European Conference, pp.346-360, 1993. ,
DOI : 10.1007/3-540-47910-4_18
Generative communication in Linda, ACM Transactions on Programming Languages and Systems, vol.7, issue.1, pp.80-112, 1985. ,
DOI : 10.1145/2363.2433
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.113.9679
Time, clocks, and the ordering of events in a distributed system, Communications of the ACM, vol.21, issue.7, pp.558-565, 1978. ,
DOI : 10.1145/359545.359563
Facebook chat. Blog entry, 2008. ,
Semantic Models for Distributed Object Reflection, ECOOP 2002 -Object-Oriented Programming, 16th European Conference, pp.1-36, 2002. ,
DOI : 10.1007/3-540-47993-7_1
Robust Composition: Towards a Unified Approach to Access Control and Concurrency Control, 2006. ,
Safe tuplespace-based coordination in multiagent systems, Applied Artificial Intelligence, vol.15, issue.1, pp.11-33, 2001. ,
Regulated coordination in open distributed systems, Coordination Languages and Models, Second International Conference, COORDINATION '97, pp.81-97, 1997. ,
How twitter is scaling Blog entry, 2009. ,
From Flow Logic to Static Type Systems for Coordination Languages, Coordination Models and Languages, 10th International Conference, pp.100-116, 2008. ,
DOI : 10.1007/978-3-540-68265-3_7
Actors, roles and coordinators -a coordination model for open distributed and embedded systems, Coordination Models and Languages, 8th International Conference, pp.247-265, 2006. ,
An overview of the K semantic framework, The Journal of Logic and Algebraic Programming, vol.79, issue.6, pp.397-434, 2010. ,
DOI : 10.1016/j.jlap.2010.03.012
Modular Specification of Interaction Policies in Distributed Computing, 1996. ,
A Hierarchical Model for Coordination of Concurrent Activities, Coordination Languages and Models, Third International Conference, COORDINATION '99, pp.166-182, 1999. ,
DOI : 10.1007/3-540-48919-3_13
Reasoning about meta level activities in open distributed systems, Proceedings of the fourteenth annual ACM symposium on Principles of distributed computing , PODC '95, pp.144-152, 1995. ,
DOI : 10.1145/224964.224981
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.35.3893
The Formal Semantics of Programming Languages, 1993. ,
Combining Static Analysis and Runtime Checking in Security Aspects for Distributed Tuple Spaces, Coordination Models and Languages -13th International Conference, pp.202-218, 2011. ,
DOI : 10.1016/S0167-6423(02)00090-4
