Coordinating Parallel Mobile Ambients to Solve SAT Problem in Polynomial Number of Steps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we present a version of mobile ambients, called parMA, having a weak form of replication and a parallel semantics. We investigate how parMA can solve intractable problems in a polynomial number of computational steps. We use parMA to give a semiuniform solution to a well-known strong NP-complete problem, namely to the Boolean satisfiability problem (SAT).
978-3-642-30829-1_9_Chapter.pdf (309.56 Ko) Télécharger le fichier
hal-01529591 , version 1 (31-05-2017)
Paternité
Bogdan Aman, Gabriel Ciobanu. Coordinating Parallel Mobile Ambients to Solve SAT Problem in Polynomial Number of Steps. 14th International Conference on Coordination Models and Languages (COORDINATION), Jun 2012, Stockholm, Sweden. pp.122-136, ⟨10.1007/978-3-642-30829-1_9⟩. ⟨hal-01529591⟩
38 Consultations
50 Téléchargements
