Interactive 3D Data Exploration Using Hybrid Tactile/Tangible Input - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Interaction hybride tactile/tangible pour l'exploration de données 3D
We present the design and evaluation of an interface that combines tactile and tangible paradigms for 3D visualization. While studies have demonstrated that both tactile and tangible input can be efficient for a subset of 3D manipulation tasks, we reflect on combinations of the two complementary input types. Based on a field study and follow-up interviews, we present a prototypical application of hybrid tactile/tangible interaction techniques for fluid dynamics data visualization using a portable, position-aware device. We briefly report on the evaluation of our approach with qualitative feedback.
abstract.pdf (1.7 Mo) Télécharger le fichier
Format : Figure, Image
hal-01529648 , version 1 (31-05-2017)
  • HAL Id : hal-01529648 , version 1
Lonni Besançon, Paul Issartel, Mehdi Ammi, Tobias Isenberg. Interactive 3D Data Exploration Using Hybrid Tactile/Tangible Input. Journées Visu 2017, Jun 2017, Rueil-Malmaison, France. ⟨hal-01529648⟩
263 Consultations
272 Téléchargements
