A Study of the RPL Repair Process Using ContikiRPL - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
Kevin Dominik Korte
  • Function : Author
  • PersonId : 1009127
Anuj Sehgal
  • Function : Author
  • PersonId : 1009114
Jürgen Schönwälder
  • Function : Author
  • PersonId : 864725
The IETF developed the RPL routing protocol for Low power and Lossy Networks (LLNs). RPL allows for automated setup and maintenance of the routing tree for a meshed network using a common objective, such as energy preservation or most stable routes. To handle failing nodes and other communication disturbances, RPL includes a number of error correction functions for such situations. These error handling mechanisms, while maintaining a functioning routing tree, introduce an additional complexity to the routing process. Being a relatively new protocol, the effect of the error handling mechanisms within RPL needs to be analyzed. This paper presents an experimental analysis of RPL’s error correction mechanisms by using the Contiki RPL implementation along with an SNMP agent to monitor the performance of RPL.
978-3-642-30633-4_8_Chapter.pdf (526.89 Ko) Télécharger le fichier
Dates and versions
hal-01529800 , version 1 (31-05-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Kevin Dominik Korte, Anuj Sehgal, Jürgen Schönwälder. A Study of the RPL Repair Process Using ContikiRPL. 6th International Conference on Autonomous Infrastructure (AIMS), Jun 2012, Luxembourg, Luxembourg. pp.50-61, ⟨10.1007/978-3-642-30633-4_8⟩. ⟨hal-01529800⟩
108 View
506 Download
Share
