RDF/SPARQL Design Pattern for Contextual Metadata - Archive ouverte HAL Access content directly
Conference Papers Year : 2007
The basic principle of the Semantic Web carried by the RDF data model is that a collection of RDF statements coex-ist all together and are universally true. However some case study imply contextual relevancy and truth. The SPARQL query language is provided with patterns enabling to choose the RDF dataset against which a query is executed. This is a first step to handle contextual metadata. Based on it, we present in this paper a design pattern to handle con-textual metadata hierarchically organized. This is done by means of a subStateOf property reifying RDF entailment between contextual graphs. The subStateOf relation is modelled within RDF and therefore context hierarchies can be described and queried by means of SPARQL queries. We propose a slight syntactic extension to SPARQL to facilitate the query of context hierarchies, together with rewriting rules to return to standard SPARQL.
wi-short.pdf (177.23 Ko) Télécharger le fichier
Dates and versions
hal-01531172 , version 1 (01-06-2017)
Identifiers
Cite
Olivier Corby, Catherine Faron Zucker. RDF/SPARQL Design Pattern for Contextual Metadata. IEEE/WIC/ACM International Conference on Web Intelligence, Nov 2007, Silicon Valley, United States. pp.474 - 477, ⟨10.1109/WI.2007.162⟩. ⟨hal-01531172⟩
109 View
168 Download
Share
