A Task-Based Model for the Lifespan of Peer-to-Peer Swarms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Peer-to-Peer (P2P) techniques are broadly adopted in modern applications such as Xunlei and Private Tracker [1,2]. To address the problem of service availability, techniques such as bundling and implicit uploading are suggested to increase the swarm lifespan, i.e., the duration between the birth and the death of a swarm, by motivating or even forcing peers to make more contributions. In these systems, it is common for a peer to join a swarm repeatedly, which can introduce substantial bias for lifespan modeling and prediction. In this paper, we present a mathematical model to study the lifespan of a P2P swarming system in the presence of multi-participation. We perform evaluations on three traces and a well-known simulator. The result demonstrates that our model is more accurate than previous ones.
978-3-642-30054-7_6_Chapter.pdf (789.45 Ko) Télécharger le fichier
hal-01531955 , version 1 (02-06-2017)
Paternité
Yong Zhao, Zhibin Zhang, Ting He, Alex X. Liu, Li Guo, et al.. A Task-Based Model for the Lifespan of Peer-to-Peer Swarms. 11th International Networking Conference (NETWORKING), May 2012, Prague, Czech Republic. pp.71-83, ⟨10.1007/978-3-642-30054-7_6⟩. ⟨hal-01531955⟩
145 Consultations
64 Téléchargements
