1Department of Computer Science [Victoria] (University of Victoria, Engineering/ Computer Science Building (ECS), PO Box 1700, STN CSC Victoria, BC Canada V8W 2Y2 - Canada)
Abstract : Connected-dominating-set (CDS) is a representative technique for constructing a virtual backbone of wireless networks. Most of existing works on CDS aim at minimizing the size of the CDS, i.e., constructing the minimum CDS (MCDS), so as to reduce the communication overhead over the CDS. However, MCDS may not work well in cognitive radio networks (CRNs) where communication links are prone to failure due to the unpredictable activities of primary users. A MCDS without consideration of stochastic activities of primary users easily becomes invalid when the primary users reclaim the licensed spectrum. In this work, we assume that the activities of primary users follow the exponential distribution. Our problem is to maximize the lifetime of the CDS while minimizing the size of the CDS, where the lifetime of a CDS is defined as the expected duration that the CDS is maintained valid. We show that the problem is NP-hard and propose a three-phase algorithm. Our basic idea is to apply a pruning-based approach to maximize the lifetime of the CDS. Given a CRN, we prove that our algorithm can compute a CDS such that i) the lifetime of the CDS is maximized (optimal); and ii) the size of the CDS is upper-bounded. To the best of our knowledge, it is the first time in the literature that CDS in CRNs is studied and an effective algorithm is proposed.
https://hal.inria.fr/hal-01531957 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, June 2, 2017 - 11:23:15 AM Last modification on : Thursday, January 6, 2022 - 12:14:04 PM Long-term archiving on: : Wednesday, December 13, 2017 - 7:40:39 AM
Zhiyong Lin, Hai Liu, Xiaowen Chu, yiu-Wing Leung, Ivan Stojmenovic. Maximizing Lifetime of Connected-Dominating-Set in Cognitive Radio Networks. 11th International Networking Conference (NETWORKING), May 2012, Prague, Czech Republic. pp.316-330, ⟨10.1007/978-3-642-30054-7_25⟩. ⟨hal-01531957⟩
