Deploying Sensor Networks With Guaranteed Fault Tolerance, IEEE/ACM Transactions on Networking, vol.18, issue.1, pp.216-228, 2010. ,
DOI : 10.1109/TNET.2009.2024941
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.217.2234
Metric Spaces: Iteration and Application, 1985. ,
Approximations for Steiner trees with minimum number of Steiner points, Theoretical Computer Science, vol.262, issue.1-2, pp.17-33, 2000. ,
DOI : 10.1016/S0304-3975(00)00182-1
Relay sensor placement in wireless sensor networks, Wireless Networks, vol.3, issue.8, pp.347-355, 2008. ,
DOI : 10.1007/s11276-006-0724-8
An application of submodular flows, Linear Algebra and its Applications, vol.114, issue.115, pp.320-348, 1989. ,
DOI : 10.1016/0024-3795(89)90469-2
URL : http://doi.org/10.1016/0024-3795(89)90469-2
Connections in Combinatorial Optimization, Discrete Applied Mathematics, vol.160, issue.12, 2011. ,
DOI : 10.1016/j.dam.2011.09.003
A representation for crossing set families with applications to submodular flow problems, Proc. SODA, pp.202-211, 1993. ,
Bounding component sizes of two-connected Steiner networks, Information Processing Letters, vol.104, issue.5, pp.159-163, 2007. ,
DOI : 10.1016/j.ipl.2007.06.009
Some structural and geometric properties of two-connected Steiner networks, Proc. CATS, pp.85-90, 2007. ,
Approximating Survivable Networks with Minimum Number of Steiner Points, Proc. WAOA, pp.154-165, 2010. ,
DOI : 10.1007/978-3-642-18318-8_14
Robust design of wireless networks, 2006. ,
Relay Placement for Higher Order Connectivity in Wireless Sensor Networks, Proceedings IEEE INFOCOM 2006. 25TH IEEE International Conference on Computer Communications, pp.1-12, 2006. ,
DOI : 10.1109/INFOCOM.2006.273
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.94.9255
Improved approximation algorithms for uniform connectivity problems, Journal of Algorithms, vol.21, pp.433-450, 1996. ,
DOI : 10.1145/225058.225066
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.22.7740
Biconnectivity approximations and graph carvings, Journal of the ACM, vol.41, issue.2, pp.214-235, 1994. ,
DOI : 10.1145/174652.174654
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.56.8290
Steiner tree problem with minimum number of Steiner points and bounded edge-length, Information Processing Letters, vol.69, issue.2, pp.53-57, 1999. ,
DOI : 10.1016/S0020-0190(98)00201-4
On the structure and complexity of the 2-connected Steiner network problem in the plane, Operations Research Letters, vol.26, issue.3, pp.111-116, 2000. ,
DOI : 10.1016/S0167-6377(99)00068-1
Low-degree minimal spanning trees in normed spaces, Applied Mathematics Letters, vol.19, issue.2, pp.122-125, 2006. ,
DOI : 10.1016/j.aml.2005.03.011
URL : http://doi.org/10.1016/j.aml.2005.03.011
A note on the MST heuristic for bounded edge-length Steiner trees with minimum number of Steiner points, Inf. Process. Lett, vol.75, issue.4, pp.165-167, 2000. ,
Wireless network design via 3-decompositions, Information Processing Letters, vol.109, issue.19, pp.1136-1140, 2009. ,
DOI : 10.1016/j.ipl.2009.07.013
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.403.4769
Low-degree minimum spanning trees, Discrete & Computational Geometry, vol.44, issue.2, pp.151-165, 1995. ,
DOI : 10.1007/BF02570700
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.49.5440
On the construction of 2-connected virtual backbone in wireless networks, IEEE Transactions on Wireless Communications, vol.8, issue.3, pp.1230-1237, 2009. ,
DOI : 10.1109/TWC.2009.051053
Vertex-disjoint paths and edge-disjoint branchings in directed graphs, Journal of Graph Theory, vol.17, issue.3, pp.349-358, 1987. ,
DOI : 10.1002/jgt.3190110309
Two-connected Steiner networks: structural properties, Operations Research Letters, vol.33, issue.4, pp.395-402, 2005. ,
DOI : 10.1016/j.orl.2004.07.010
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.3.4817
